Logging GPS using Logomatic V2
I have for some time been attempting to log my Garmin 2 plus NMEA output on Logomatic. Th GPS output is 0 to 5 volts @4800 baud and from what I read the Logomatic setup clearly includes these settings. I have used both Sparfun’s latest firmware as well as Kwan’s modofied firmware.
I have checked the GPS output on an oscilloscope and the output is as defined in NMEA specs (ie as above). Has anyone managed to log such a data stream ? I would appreciate any advice. I have also tried adding a Sparkfun RS 232 shifter and it works well when connecting to my laptop’s hyperterminal. However my aim is to avoid using a laptop and log either with the Logomatic or OpenLog and I have tested both. To date raw connections to either have been unsuccessful.
Here’s some examples of data collected to date plus settings…The actual output was NMEA GPS as shown at the end of the examples below…
MODE = 0
ASCII = Y
Baud = 3
Frequency = 100
Trigger Character =
Text Frame = 200
AD1.3 = N
AD0.3 = N
AD0.2 = N
AD0.1 = N
AD1.2 = N
AD0.4 = N
AD1.7 = N
AD1.6 = N
Saftey On = Y
쁦绦飳曾黼绾蛏약쮝�皶盭枺媳癖ᚭ뎲�쒳鮧ꞏꞧꎛꞕꎛꞟꎙꮟ鶙熷煟卙馧鶧鶧ꞟ鮟馧Ɥ閙ꞕ鞗龧ꞗ鮓龧龓鞧ꞏ趟閧ꞗ鞛ꞓ鎗鶧ꞛ鶛鮧鞙馧ꮍ疑熷煟卙馧鮧鶧ꞟ閝龧ꞏ鶙ꞕ鮙鶧ꞑ鮗鶧辙鞧ꞕ龛龧ꞝ鮝ꞑ龟鮧ꞓ閟鮧鎛馧ꮟ箑熷煟卙馧馧鶧ꞟ醛鎧ꞝ鎛ꞗ醗鮧ꞏ醝龧趑馧ꞏꞧꞧꞧꮧ龑德孱略鶧ꎕꞟꝥ鮛閣斧鶧ꎕꞟꭥ箝熷煟杧馧鮙ꎓ鮍ꞑꝙ閝鶝ꎙ醕ꞟꝵ鎟閝龕綧馫럫煟敛ꝋ醝㎧馧鮫럫煟敛ꝥ煑뽙鞏龫럫影慻ꝷ龟ꎓꞗꝗ閙ꎗꞝꝥ齗鶟垧龟ꮛ閗熷兟束馧鶗ꎝ鎙ꞗꝙ閝龝ꎙ趍ꞏꝵ齗鞝馫ë깛喵鴫滻噙홖굶쮝똮㘶곭�ꭚ噚훖㚖릭敤흚㛶盭㘶맭홚뛶뛖ⴶ굶떯庲뵹깛喵鵫鷫滻浶皶ꗭ훶⵶㚖泭嚺噚泶斺늲흚 雚㘖皭녬�婚굶ﮭ埦뷞깛씕鷵盻噙홖⵶뚖㘶坚噚훖㚖놭敤흚癚훭뫬뒳굶뒹婦�쾳鮣斧ꞧ閫럫影奱ꝽꝽꞙ鮟龧ꞗ趟鶧ꞛ閝鶧ꞑ鮧ꞓ醛鮧ꞏꞧꎛꞕꎛꞟꎙꮟ鶙熷煟卙馧鶧鶧ꞟ鮟馧Ɥ閙ꞕ鞗龧ꞗ鮓龧龓鞧ꞏ趟閧ꞗ鞛ꞓ鎗鶧ꞛ鶛鮧鞙馧ꮍ疑熷煟卙馧鮧鶧ꞟ閝龧ꞏ鶙ꞕ鮙鶧ꞑ鮗鶧辙鞧ꞕ龛龧ꞝ鮝ꞑ龟鮧ꞓ閟鮧醛馧ꮟ綑 熷煟卙馧馧鶧ꞟ醛鎧ꞝ鎛ꞗ醗鮧ꞏ醝龧趑馧ꞏꞧꞧꞧꮧ龑德孱略鶧ꎕꞟꝥ鮛閣斧鶧ꎕꞟꭥ箝熷煟杧馧鮙ꎓ醏ꞛꝙ閝鶝ꎙ醕ꞏꝵ鎟閝鮕綧馫럫煟敛ꝋ醝㎧馧鮫 럫煟敛ꝥ煑뽙鞏龫럫影慻ꝷ龟ꎓꞗꝗ閙ꎗꞝꝥ齗鶟垧龟ꮛ閗熷兟束馧鶗ꎟ鞍ꞙꝙ閝龝ꎕ龟Ɥꝵ齗馝馫ë깛喵鴫盻噙陖굶쮝똮㘶Ⳮ嚲噚훖㚖릭癬Ɬ㛶盭㘶 맭홚뛶뛖ⴶ굶떯枲뵹깛喵鵫鷫盻浶皶귭훶⵶㚖泭嚺噚泶斲늲흚雚㘖癭륬�婚굶ﮭ垦뷞깛씕鷵盻噙陖⵶뚖㘶Ⳮ皖甭嚭훖㚖놭瘬꾭癚훭뫬뒳굶뒹 婦�쾳鮣斧ꞧ閫럫影奱ꝽꝽꞙ鮟龧ꞗ趟鶧ꞛ閝鶧ꞑ鮧ꞓ醛鮧ꞏꞧꎛꞕꎛꞟꎙꮟ鶙熷煟卙馧鶧鶧ꞟ鮟馧Ɥ閙ꞕ鞗龧ꞗ鮓龧龓鞧ꞏ趟閧ꞗ鞛ꞓ鎗鶧ꞛ鶛鮧鞙馧ꮍ疑 熷煟卙馧鮧鶧ꞟ閝龧ꞏ鶙ꞕ鮙鶧ꞑ鮗鶧辙鞧ꞕ龛龧ꞝ鮝ꞑ龟鮧ꞓ閟鮧醛馧ꮟ綑熷煟卙馧馧鶧ꞟ醛鎧ꞝ鎛ꞗ醗鮧ꞏ醝龧趑馧ꞏꞧꞧꞧꮧ龑德孱略鶧ꎕꞟꝥ鮛閣斧鶧ꎕꞟꭥ箝熷煟杧馧鮙ꎓ鶏ꞓꝙ閝鶝ꎙ辕ꞕꝵ鎟閝鞕綧馫럫煟敛ꝋ醝㎧馧鮫럫煟敛ꝥ煑뽙鞏龫럫影慻ꝷ龟ꎓꞗꝗ閙ꎗꞝꝥ齗鶟垧龟ꮛ閗熷兟束馧龗ꎏ鎑ꞑꝙ閝龝ꎏ閛ꞛꝵ齗鮝馫ë깛喵鴫盻噙噖굶쮝똶㘶뤭瘬甭嚭훖㚖놭癣꾭㛶盭㘶뇭홚뛶뛖ⴶ굶떷徲뵹깛喵鵫鷫曻浶皶귭훶⵶㚖泭嚺噚泶斶늲흚雚㘖癭륬�婚굶ﮭ垮뷞깛씕鷵曻噙噖⵶뚖㘶넭孚噚훖㚖릭癣꾭癚훭뫬뒳굶뒹婦�쾳鮣斧ꞧ閫럫影奱ꝽꝽꞙ鮟龧ꞗ趟鶧ꞛ閝鶧ꞑ鮧ꞓ醛鮧ꞏꞧꎛꞕꎛꞟꎙꮟ鶙 熷煟卙馧鶧鶧ꞟ鮟馧Ɥ閙ꞕ鞗龧ꞗ鮓龧龓鞧ꞏ趟閧ꞗ鞛ꞓ鎗鶧ꞛ鶛鮧鞙馧ꮍ疑熷煟卙馧鮧鶧ꞟ閝龧ꞏ鶙ꞕ鮙鶧ꞑ鮗鶧辙鞧ꞕ龛龧ꞝ鮝ꞑ龟鮧ꞓ閟鮧醛馧ꮟ綑熷煟卙馧馧鶧ꞟ醛鎧ꞝ鎛ꞑ醗鮧ꞏ醝龧趑馧ꞏꞧꞧꞧꮧ馑德孱略鶧ꎕꞟꝥ鮛閣斧鶧ꎕꞟꭥ箝熷煟杧馧鮙ꎓ鎑ꞝꝙ閝鶝ꎙ趕ꞙꝵ鎟閝鎕綧馫럫煟敛ꝋ醝㎧馧鮫럫煟敛ꝥ煑뽙鞏龫럫影慻ꝷ龟ꎓꞗꝗ閙ꎗꞝꝥ齗鶟垧龟ꮛ閗熷兟束馧龗ꎕ鶕ꞙꝙ閝鶝ꎛ鎗ꞟꝵ齗鶝馫ë깛喵鴫滻噙ᙖ굶쮝똮㘶뤭孚噚훖㚖릭摣흚㛶盭㘶맭홚 뛶뛖ⴶ굶떯嶲뵹깛喵鵫鷫滻浶皶ꗭ훶⵶㚖泭嚶噚泶斺늲흚雚㘖瘭녬�婚굶ﮭ坶뷞깛씕鷵滻噙ᙖ⵶뚖㘶뤭뎳ꭚ噚훖㚖릭흚癚훭뛬뒳굶뒹婦� 잳鮣斧ꞧ閫럫影奱ꝽꝽꞙ鮟龧ꞗ趟鶧ꞛ閝鶧ꞑ鮧ꞓ醛鮧ꞏꞧꎛꞕꎛꞟꎙꮟ鶙熷煟卙馧鶧鶧ꞟ鮟馧Ɥ閙ꞕ鞗龧ꞗ鮓龧龓鞧ꞏ趟閧ꞗ鞛ꞓ鎗鶧ꞛ鶛鮧鞙馧ꮍ疑熷煟卙馧鮧鶧ꞟ閝龧ꞏ鶙ꞕ鮙鶧ꞑ鮗鶧辙鞧ꞕ龛龧ꞝ鮝ꞑ龟鮧ꞓ閟鮧醛馧ꮟ綑熷煟卙馧馧鶧ꞟ醛鎧ꞝ鎛ꞑ醗鮧ꞏ醝龧趑馧ꞏꞧꞧꞧꮧ馑德孱略鶧ꎕꞟꝥ鮛閣斧鶧ꎕꞟꭥ箝熷煟杧馧鮙ꎓ龑ꞓꝙ閝鶝ꎙ龓ꞟꝵ鎟閝辕綧馫럫煟敛ꝋ醝㎧馧鮫럫煟敛ꝥ煑뽙鞏龫럫影慻ꝷ龟ꎓꞗꝗ閙ꎗꞝꝥ齗鶟垧龟ꮛ閗熷兟束馧龗ꎗ鞗ꞟꝙ閝鶝ꎟ鎍ꞕꝵ齗龝馫ë깛喵鴫滻噙홖뛬婟캳鎛鎣馑妧鶧鶕馝鎣鞟疧鶧龟龣龧鎟鞣鶧龝鶛ꞟ鶟ꎛꞙꭵ鎓熷孟筥綧龧龣ꞟꝛ齗鮟垧龟ꞝ鞙馟辣辛妧鶧鶕辟閣鎓疧龧醙馣鶧鎏鞣ꖧ龝ꎟꞟꭽ玟熷煟統龧鶓閕Ɥ香鎛鎣醓妧鶧鶕馝鎣閟疧鶧龧Ɥꎛꞟꎕꞙꝥ鶛鮣斧ꞧ閫럫影奱ꝽꝽꞙ鮟龧ꞗ趟鶧ꞛ閝鶧ꞑ鮧ꞓ醛鮧ꞏꞧꎛꞕꎛꞟꎙꮟ鶙熷煟卙馧鶧鶧ꞟ鮟馧Ɥ閙ꞕ鞗龧ꞗ鮓龧龓鞧ꞏ趟閧ꞗ鞛ꞓ鎗鶧ꞛ鶛鮧鞙馧ꮍ疑熷煟卙馧鮧鶧ꞟ閝龧ꞏ鶙ꞕ鮙鶧ꞑ鮗鶧辙鞧ꞕ龛龧ꞝ鮝ꞑ龟鮧ꞓ閟鮧醛馧ꮟ綑熷煟卙馧馧鶧ꞟ醛鎧ꞝ鎛ꞑ醗鮧ꞏ鎝龧辑馧ꞑꞧꞧꞧꮧ禑德孱略鶧ꎕꞟꝥ鮛閣斧鶧ꎕꞟꭥ箝熷煟杧馧鮙ꎓ間ꞟꝙ閝鶝ꎙ龓ꞑꝵ鎟鎝龟綧馫럫煟敛ꝋ醝㎧馧鮫
MODE = 0
ASCII = Y
Baud = 3
Frequency = 100
Trigger Character = $
Text Frame = 100
AD1.3 = N
AD0.3 = N
AD0.2 = N
AD0.1 = N
AD1.2 = N
AD0.4 = N
AD1.7 = N
AD1.6 = N
Saftey On = Y
æx3xÆþ[®µU+
