Anybody know what the max APB clock (PCLK) rate is for the LPC2103? I can’t find a spec for it, but there is a divider circuit and an explanation that the divider circuit is there to make sure that APB works…
Thanks.
Thanks.
Max PCLK is CCLK which is 70 MHz (or 60 MHz, i forget).
Just set the APBDIV to 1 to set it to the same as processor clock. Then set that to whatever you want.
