I am working with the MAX31820 sensor and can’t figure out if this needs to be calibrated.
Can you see if I should be calibrating this temperature sensor? Or is there documentation saying calibration isn’t needed?
The MAX31820 does not require calibration.
Please see the [data sheet for more information.](https://cdn.sparkfun.com/datasheets/Sensors/Temp/MAX31820.pdf)
