When I sent in my latest set of boards, I forgot to connect a few connections to the ground plane on the other side. There is a via, but the net is not set to ground, so on the ground plane side, there is a soldermask between the trace and the ground plane. Is there any way to bypass this and manually solder the trace to the ground plane?
