I have assembled your
SparkFun Thing Plus ESP32-S3 — Main microcontroller board (ESP32-S3-MINI1-N4R2, dual-core 240MHz, 4MB Flash, 2MB PSRAM, WiFi/BLE, USB-C)
SparkFun GPS-RTK Board — NEO-M8P-2 (Qwiic) — GPS receiver with RTK/PPK capability (I2C 0x42, 25mm RTK accuracy, 2cm PPK with CORS, 10Hz NAV rate)
SparkFun LSM6DSV16X 6-DoF IMU (Qwiic) — Inertial measurement unit with 3-axis accelerometer + 3-axis gyroscope (I2C 0x6B, ±4g accel, ±500dps gyro, 120Hz ODR)
the https://www.sparkfun.com/molex-flexible-gnss-antenna-u-fl-adhesive.html works well - although the cable is rather short - any options?
and got it all going.
Now I would like to assemble it much more elegantly in the smallest possible enclosure and also run it on a 8 hour LIPO battery
is there a single board that combines this functionality or can I commission a build?
can I use https://www.sparkfun.com/micromod for this purpose?
