Myoware 2.0 Discontinuity
I purchased two myoware 2.0 boards and both were not reporting data as expected. I used my multimeter to check the continuity of my electrode pads and got that the top part of the electrode pad (the male side) was open when compared to the back of the electrode pad. I am unsure how to fix this issue because it is on both my boards and I can’t obtain any signals since the pins are discontinuous.
Can you share photos of the areas you’re referencing?
When I attach my leads of my DMM to the top of the metal electrode tab (blue box) and then one at the bottom (green box) it measures as discontinuous.
They are not connected by design. See the hookup guide for the reason.
