No signal from Myoware 2.0
unfortunately I am currently facing issues with the MyoWare2.0.
I have one MyoWare 1.0 sensor that works perfectly fine with my setup. When replacing the sensor with the MyoWare 2.0, I can’t get any signals out of it.
I followed the whole “Getting Started” Tutorial on the Sparkfun webpage and read the documentation provided by MyoWare.
What I already tried:
  • replacing cables between Arduino and notebook
  • replacing cables between Arduino and sensor
  • brading cables
  • using the notebook without beeing plugged to the wall
  • replacing the Arduino
  • replacing the sensor (I have two MyoWare 2.0 sensors: one with cut jumper pad, one with original)
  • switching between 3.3 V and 5 V supply voltage
  • cleaning the skin before applying electrodes and using new electrodes every time
  • trying diffrent positions on different muscles (biceps, forearm)
  • using the built-in reference snap connector with original jumper pad
  • using the reference cable with cut jumper pad
  • adjusting the gain
  • changing the baud rate to 115200 as in the example code
All I ever get out of the sensor is just a constant 0 or 1023 or maybe some noise from moving/touching the cables. I am just wondering why it is working with the MyoWare 1.0 and not with the MyoWare 2.0.
Any ideas welcome!
Please find photos of my setup here:
https://photos.app.goo.gl/XQUhr12qkn4wuRAb9
Thank you!
Awww really sounds like a bad sensor. Because you have tried pretty much everything to troubleshoot. Quite unusual for a SparkFun product though.
