NOT getting 5V TTL logic from my Altair 8800c computer through the SparkFun RS232 Shifter - SMD?
I am NOT getting 5V TTL logic from my Altair 8800c computer through the SparkFun RS232 Shifter - SMD.
The output from my Altair 8800c computer on the RS-232 cable:
https://www.brainless.org/Altair/OtherS … RS-232.jpg
The output from the RS232 Shifter connected to my Altair 8800c via the RS-232 cable:
https://www.brainless.org/Altair/OtherS … hanger.jpg
My problem is I need real 5V TTL level signals to control other TTL serial IN devices like the; Micro Maestro 6-Channel USB Servo Controller https://www.pololu.com/product/1350
Are you powering the shifter pcb with 5 volts?
I’ve used a 9v to the Maestro 6 (5V-16V) input, and I’ve used a bench power supply set at 5V and 10A … No matter, the output is still not a full 5V TTL level signal.
