Has anyone here used MSPGCC with Olimex JTAG-TINY?
Thanks in advance
Victor
Thanks in advance
Victor
AFAIK the mspgcc tools only work with the original parallel FET.
Leon
hi,
several customers of ours reported that they use Tiny and Iso with MSPGCC but we never try, you can ask on MSPGCC list or look at this list archives there should be postings how to set the enviroment
Best regards
Tsvetan
Thank you to Leon and Tsvetan for your colaboration.
Best regards.
Victor
I tried a search but couldn’t find anything. I normally use CrossWorks, anyway. They don’t support bi-wire. 8-(
Leon
leon_heller:
AFAIK the mspgcc tools only work with the original parallel FET.Leon
I’ve got the TI msp430FET USB JTAG device working with mspgcc/gdbproxy so if the Olimex device is similar, it might work.
but the MSPGCC tools definitely work with the TI USB JTAG tool on Linux. And there’s no need to tweak the driver to recognize it anymore since the kernel supports it directly.
leon_heller:
I tried a search but couldn’t find anything. I normally use CrossWorks, anyway. They don’t support bi-wire. 8-(Leon
Check out the latest build (v1.4 build 3). Its on the relase notes.
vitomsc:
Has anyone here used MSPGCC with Olimex JTAG-TINY?Thanks in advance
Victor
Yes! I am successfully using it. Worked with:
