Hi
I’ve just received a coupe of Olimex LPC-E2294 rev B but I can’t get them to communicate! When I use USB for power the test program runs fine and displays Board Test and then Test Success. I then set the BSL-jumper and resets the board but the Phillips Flash Utility can’t connect. I have two older boards of the first version (green instead of red circuit board) and they work great.
What’s different with the new revision and what shall I do to be able to flash the new boards using Phillips Flash Utility?
Best Regards
/David
