Pads in the PCB but not in the schematic?
How can one put pads (For like a prototyping area) on the PCB without adding them to the schematic? In Eagle Cad that is.
-Pete
Place vias.
You can either add test points to the schematic or just draw a box on the top or bottom layer with a line connecting it.
I think it is much better to actually add a test point into the schematic. The libraries for Eagle come with both through hole and surface mount test points.
