I have just discovered how to make panelized designs in eagle. I am planning to get these done at goldphoenix. I have a total of 9 designs that I have placed into one eagle->gerber file. The tell me that I will need to do the depanelization myself if its over 6 designs per panel.
Can anyone tell me what depanelization means? Does this mean that I need to provide one big gerber file with all pcb’ls and individual pcb’s or does this mean that I will need to cut out the individual pcb’s myself?
If anyone has done a panelized project please explain the process. Thank you!
HakBot:
GP will run a whole panel with your Gerbers (and
Excellon drills). The entire panel will be sent to you
as a whole. You need to cut the smaller projects
out of the panel by hand.
Why not double up on the number of pieces per
design on a panel, limit yourself to six unique designs
will GP do V-scoring? If so then you could just snap them apart. You’d need to provide a file with the V-score lines in it. Heck, GP might be willing to do it all.
With 6 unique designs gold phoenix will route them out for me. Anything above 6 I will need to do the individual pcb separation? So depanelization means routing the boards out?
Is there a standard panel size? If I specify a panel size thats 5"x10" i should be able to get 3 panels for the 155sq in pcb deal correct?
In my case I don’t think I could do this. GP requires all designs to be the same size.
Even if you do the panelizing yourself? Not hard at all. check out gerbmerge.
