I have new SIK v4.1 kits for some students and we are having a very hard time with the new boards. We are using Windows 10 machines. We’ve updated Arduino and installed the drivers available here (https://learn.sparkfun.com/tutorials/ho … leshooting). The CH340 shows up in device manager under ports.
In the Arduino IDE I opened the Blink program, chose the Uno board, and selected the COM port that matches the CH340 in Device Manager. It says Uploading… but then errors out with this message:
Reading | ###############################avrdude: stk500_recv(): programmer is not responding
avr_read(): error reading address 0x0000
read operation not supported for memory “flash”
avrdude: failed to read all of flash memory, rc=-2
avrdude done. Thank you.
the selected serial port
does not exist or your board is not connected
The cable works fine. I can download to the old RedBoards and other Arduinos just fine. Every once in a while it decides to work and the program will load, but I haven’t found a pattern. I’ve tried restarting the computer, switching to other known good cables, other computers, pressing the reset button, unplugging and replugging the USB. There is nothing connected to the board on any pin.
What am I missing?
