Hi all,
I’m trying to use the AVRJTAG with the atmega128 and AVRStudio.
I’ve updated the AVRJTAG with the AVRStudio as described on the OLIMEX page. Now I load the *.cof file of my application and choose in AVRStudio the JTAG ICE platform and ATmega128 device.
The application is not running on the device and if I break the execution, AVRStudio will give me the following error messages:
Loaded partfile: D:\Programme\Atmel\AVR Tools\PartDescriptionFiles\ATmega128
Loaded objectfile: D:\Projekte\Atmel_AVR\Test_128\test_128.cof
Error reading memory IO Address:0 Size:64
Error reading memory REGISTERS Address:0 Size:32
Error reading memory SRAM Address:96 Size:160
JTAG ICE Warning: Reading the program counter, an invalid value (0x7FFFFFFF) was received from the device.
Error reading programcounter
I can read the signature and handle the fuses in the JTAG ICE dialog box.
Both fuses - OCDEN and JTAG - are correct (marked).
What I’m doing wrong. Do I need a bootloader already installed in the device?
Any suggestions?
Andreas
