Hi I have a question when investigating how to correctly solder the FSR. I want to implement a project which has limited area for the FSR, so if possible, I would like to go with the solution as what the attchments are shown.
But I read the sparkfun FSR integration guide: Do not kink or crease the tail of the FSR device
So how does the following attachments work? It seems that they are bending the sensor.
Thx
harry
Hi Harry.
What SparkFun part number are you inquiring about?
TS-Chris:
Hi Harry.
Hi Chris,
I am checking with Force Sensitive Resistor - Small - SEN-09673 or some similar small FSRs. But my question is more about how to understand the FSR integration guide - Do not kink or crease the tail of the FSR device.
What does the “tail” here refer to?
Can I bend the staple part like the previous attached pics?
Thx
Harry
Hello Harry.
The “tail” refers to the section of conductor between the actual sensor and the metal pins. The solder tabs themselves can be bent, but you don’t want sharp bends in the tail. If you need a shorter tail, you can cut the tail and then crimp on a new set of solder tabs like part number [COM-14195.](Amphenol FCI Clincher Connector (2 Position, Male) - COM-14195 - SparkFun Electronics)
You can go shorter, we just say that in the guide to keep customers from cutting the sensor too short and not having enough lead left to make a crimp. Measure twice, cut once!
