I recently purchased Raspberry Pi 400 (https://www.sparkfun.com/products/17376) and I am having issues booting it up. I followed the Beginner’s Guide and plugged in the mouse, ethernet cable, official micro HDMI cable (to the left port, I tried both anyway), SD card (written with both Raspberry Pi Imager and Balena Etcher and with latest Raspbian as well as Manjaro on both 16GB and 64GB Samsung cards) and then plugged in the official USB-C charger. The only sign of life from the device is a few flashes of the power LED (not sure how to count them in order to refer to this post explaning number of LED flashes: https://www.raspberrypi.org/forums/view … 28&t=58151, see attached video for a demonstration). I followed this https://support.thepihut.com/hc/en-us/a … -is-faulty troubleshooting guide and I can rule out all of the possible causes.
Wrong HDMI port: Tried both
Old/Wrong Operating System: Used the latest image from Raspberry Pi foundation website
Power Supply: Using the official white USB-C power supply for Rpi 4
SD Card quality: SD cards are Samsung and Sandisk (16GB and 64GB respectively) and I can see the files inside on my main computer
Re-seat SD card: Done that
Corrupted SD Card: 1- I can read the cards as I explained earlier, 2-the issue is more fundamental: even without putting the SD card in, the device doesn’t turn on the power light, let alone show any boot screen on the monitor.
Check the Indication LEDs: The power LED briefly flashes (I think 3-4 times but it depends on how you “count” those flashes. See the attached video.)
Is there anything I should try before returning the device and claim a replacement?
output3.rar (2.61 MB)
