Redboard ISP Programmer pin direction
Hi I have built the USBTinyISP AVR Programmer, and i want to program a Sparkfun Redboard. There are the 6pin ISP connectors, but i don’t see any indication of what direction you’re supposed to attach the cable. How do i tell which direction to attach the connector, or which pin is which?
If you built it then you should have labeled it… http://goo.gl/L8M4IR
I believe he’s talking about the Redboard not being labelled.
It is, but it’s hard to see. There’s a small vertical line next to pin 1 on the silkscreen. Check the photo for the retired version:
https://www.sparkfun.com/products/retired/11575
