I’m looking for a LED PCB ring that meets the following specifications :
- External diameter of 60.0 mm maximum
- Internal diameter of 45.0 mm minimum
- Essential lighting colors: Red - Green - Blue
- If possible, the device can withstand splashes
I think the COM-14966 model can meet my needs, but I need the following details:
- The inner and outer circular parts of the ring seem to be removable. Is this the case ?
- The inside diameter of the device is not given. Is it possible to have it ?
Thank you in advance for your feedback.
