Regarding Gator:bit (v1)
Briefly: the difference between v1 (retired) [which I have] and v2:
From support: [The] “main difference is that the v1 board uses a JST connector and the v2 uses a barrel jack connector.”
I’m working with my elementary school 4th-grade son and his very busy STEAM educator.
Fred
I could “read the specs” but which flavor of “JST” is it? I have other boards that happen to use the 1mm “JST SH” form factor.
JST-PH, 2mm spacing.
There are also some solder pads convenient.
Version 1:
https://www.sparkfun.com/products/retired/14484
