I wanted to point out 2 things, so managment can look into it and fix it.
Sparkfun said, that it will include extra replacement resistor for faulty RED-V boards (viewtopic.php?f=173&t=51613). The replacement resistor which I received has the same value as incorect one. Please check, if it is widespread issue.
The RED-V board’s screw hole near Power barrel jack has 1mm offset, which causes problems inserting board into standard Arduino case. Please be good and fix this issue.
