The RFM22B can be purchased with a part number suffix for 433, 868, 915MHz.
It seems SFE sells only the 433MHz module.
In North America, the 915MHz band is much preferrable to 433MHz because of the FCC regulations for 433MHz. In 433, the transmitter duty cycle and power are seriously limited to preclude interference. The transmitter duty cycle (transmissions per minute), is very low.
