Somewhat frustrated here because it seems like connecting to the RN-XV should be very straightforward - but nothing I have tried has worked.
This is what I have:
https://www.sparkfun.com/products/10822
I’ve tried connecting to the RN-XV via the FTDI basic board (https://www.sparkfun.com/products/9716) that I have - I cut the connection between the 5v pad and soldered up the connection to the 3.3v pad - I confirmed with a DMM that the connection was broken and that 3.3v was produced.
Hooking the RN-XV up to the FTDI board (soldered jumper wires on the RN-XV plugged in to the sockets on the FTDI) resulted in no LEDs lighting on the RNXV, and when I entered $$$ in teraterm to get in to the RN-XVs setup utility, I did not received a CMD response as listed in the manual.
I re-tried this configuration using the 3.3v output of my arduino board - thinking that maybe the FTDI couldn’t pass as much current as the RN-XV needed - still no response.
I then gave the ADHOC mode a shot - soldering a wire between the 3.3v power and pin 8. In this configuration, LED D1 lit up solid - but I could not find the allegedly generated network on either my PC laptop or iphone.
I’m about fresh out of ideas for getting this to work - maybe its defective? Any help regarding troubeshooting, setup, etc would be greatly appreciated.
-Chris
