RN-XV with WiFi Extender WN3000RP
I am able to successfully tweet messages with the RN-XV connected to an arduino through the main wifi router but if I try to connect through a wifi extender (WN3000RP) the network will see the arduino when I map the connected devices, but it will no longer operate. I need the extender to have a good signal to get to a standby generator.
I’ve made sure both the router and the extender have the most up to date connections.
any suggestions on tweaking the software or is this a limitation of the RN-XV?
thank you
