RN171 Firmware update problem
I am trying to update firmware - so I am using these commands:
set wlan sssid
set wlan pass
save
join
set ftp address 0
set dns name RN.MICROCHIP.COM
ftp update wifly7-400.mif
What I get is these messages back:
<2.32> FTP connecting to 0.0.0.0
FTP timeout=2
IF=UP
DHCP=ON
IP=169.254.187.231:2000
NM=255.255.0.0
GW=0.0.0.0
Listen on 2000
What does this mean? - connection fail? server respond?
Can any one try to explain what is the problem here?
Roee :oops:
I could finally update firmware to version 4
but I have found many other problems,
Can any one help with questions?
can any one that worked with this one send me his email?
Thanks in advanced
Roee
It helps if you tell what the problems are…
Also, for the benefit of others, it helps to report the solution to a problem that you posted.
Otherwise you just waste time and space on the forum.
