I’m looking to replace this controller and not sure the 3axis model will work for me. Not to savy as this, homemade cnc is giving me grief and current controller is out of date I believe. Stepper motors currently installed are 2.0A 1.8deg/step Model: 57BYGH402-2.
Thanks in advance for any suggestions
Hello, and thanks for your post.
The Stepoko is manufactured on a RoHS production line and with lead free solder and should be RoHS compliant but we don’t have any certification that says so.
One other thing: These work fine with the Universal G-code Sender software, (or any GRBL 0.9 compatible software) but if you plan on using them with Carbide 3D’s software you will need to get Carbides special version of the software that works with the Stepoko.
