When I got it, I turned on it and it worked well. After test, it’s firmware version was 1.6, so I updated firmware to 1.10 through Updating Firmware From CLI in Hook up guide. But after update, I can’t on it’s power. And when I connect to charger, power led turn on only about 3 seconds and offed. It not response how long I push power button.
How can I turn on it???
weird problem. Did anyone from team sparkfun contact you regarding this issue?
The same thing happened to me.
I wasn’t getting RTK corrections via NTRIP, so I thought I’d update to the latest version of firmware - from firmware version 1.8 (Oct 2021) to version 1.12. When I finally updated the firmware via the command line interface, I lost the ability to turn the device on with the Power button.
Did you get a fix from Sparkfun? I’m not sure what to do next.
hyunkil:
