RTK Express not reconnecting to server after unsucessful connect
we are using the RTKExpress in fields with bad mobile reception. Sometimes the mobile internet uplink drops completely.
In that case the RTKExpress drops from casting to xmitting status, and does not send any data to the caster server anymore.
Could you please add an automatic reconnect (with incremental stepbacks) to attempt to reconnect to the caster server?
Thank you and thanks for the support!
PS: in case this feature already exists in more recent software versions please tell me - at least it is not documented in the manual.
File an ‘issue’ here https://github.com/sparkfun/SparkFun_RT … are/issues with as much detail as possible for the best chance of the feature being implemented
