RTK Facet L-Band Base not Casting to NTrip Server via WiFi and Cellular hotspot
Hello. In base mode when I try to set up a temporary base with the RTK Facet L-Band after “Survey In” it transmits the RTCM messages but does not connect to my EMLID NTrip casting site through the cellular hotspot. I have the same credentials set up for my RTK Facet and it reads X-mitting for about 4 seconds and then reads Casting. The L-Band reads X-mitting but does not cast. I just updated to version 2.6 hoping that would solve the problem but with no luck. Is this an isolated problem or has anyone else experience the same phenomenon
Hello. I have a facet and I use it based on ntrip with Rtk2go and sometimes with Emlid.
Sometimes what you propose has happened to me and the solution has been to turn the equipment off and on.
Question from me.
The WIFI connection of the cell phone works correctly right?
On the other hand I have had problems with the latest firmware versions. It emits corrections very slowly and comes to a stop.
Version 2.6 of 10/13 has worked very well for me.
Not the final 2.6
I’ve encountered the same and cutting it off and restarting has worked for both the Facet and Express models. I’ve had no such luck with the Facet L-Band.
I believe this issue was reported here by amlago: https://github.com/sparkfun/SparkFun_RT … issues/362
We’ve solved it but unfortunately the fix is currently in the development firmware. Please give the latest release candidate at try: https://github.com/sparkfun/SparkFun_RT … tag/v2.7RC
Please open an issue on the github repo if you continue to find problems: https://github.com/sparkfun/SparkFun_RT … are/issues
