Hi there,
We recently purchased the RTK Surveyor for testing reasons. We were trying to compile the Arduino firmware but it returns some errors. Please could you give us some suggestions in order to finally compile the Arduino firmware? It seems like some macros are not defined, they are not found in the whole project, is it something we need to add?
Error Message:
WARNING: library JC_Button claims to run on avr architecture(s) and may be incompatible with your current board which runs on esp32 architecture(s).
C:\Users\LENOVO\Documents\Arduino\Projects\RTK_Surveyor\src\BluetoothSerial\BluetoothSerial.cpp: In function ‘void esp_spp_cb(esp_spp_cb_event_t, esp_spp_cb_param_t*)’:
C:\Users\LENOVO\Documents\Arduino\Projects\RTK_Surveyor\src\BluetoothSerial\BluetoothSerial.cpp:268:34: error: ‘ESP_BT_CONNECTABLE’ was not declared in this scope
esp_bt_gap_set_scan_mode(ESP_BT_CONNECTABLE, ESP_BT_GENERAL_DISCOVERABLE);
C:\Users\LENOVO\Documents\Arduino\Projects\RTK_Surveyor\src\BluetoothSerial\BluetoothSerial.cpp:268:54: error: ‘ESP_BT_GENERAL_DISCOVERABLE’ was not declared in this scope
C:\Users\LENOVO\Documents\Arduino\Projects\RTK_Surveyor\src\BluetoothSerial\BluetoothSerial.cpp: In member function ‘bool BluetoothSerial::connect(String)’:
C:\Users\LENOVO\Documents\Arduino\Projects\RTK_Surveyor\src\BluetoothSerial\BluetoothSerial.cpp:861:34: error: ‘ESP_BT_CONNECTABLE’ was not declared in this scope
C:\Users\LENOVO\Documents\Arduino\Projects\RTK_Surveyor\src\BluetoothSerial\BluetoothSerial.cpp:861:54: error: ‘ESP_BT_GENERAL_DISCOVERABLE’ was not declared in this scope
C:\Users\LENOVO\Documents\Arduino\Projects\RTK_Surveyor\src\BluetoothSerial\BluetoothSerial.cpp: In member function ‘bool BluetoothSerial::connect()’:
C:\Users\LENOVO\Documents\Arduino\Projects\RTK_Surveyor\src\BluetoothSerial\BluetoothSerial.cpp:905:34: error: ‘ESP_BT_CONNECTABLE’ was not declared in this scope
C:\Users\LENOVO\Documents\Arduino\Projects\RTK_Surveyor\src\BluetoothSerial\BluetoothSerial.cpp:905:54: error: ‘ESP_BT_GENERAL_DISCOVERABLE’ was not declared in this scope
C:\Users\LENOVO\Documents\Arduino\Projects\RTK_Surveyor\src\BluetoothSerial\BluetoothSerial.cpp: In member function ‘BTScanResults* BluetoothSerial::discover(int)’:
C:\Users\LENOVO\Documents\Arduino\Projects\RTK_Surveyor\src\BluetoothSerial\BluetoothSerial.cpp:971:30: error: ‘ESP_BT_CONNECTABLE’ was not declared in this scope
C:\Users\LENOVO\Documents\Arduino\Projects\RTK_Surveyor\src\BluetoothSerial\BluetoothSerial.cpp:971:50: error: ‘ESP_BT_GENERAL_DISCOVERABLE’ was not declared in this scope
C:\Users\LENOVO\Documents\Arduino\Projects\RTK_Surveyor\src\BluetoothSerial\BluetoothSerial.cpp: In member function ‘bool BluetoothSerial::discoverAsync(BTAdvertisedDeviceCb, int)’:
C:\Users\LENOVO\Documents\Arduino\Projects\RTK_Surveyor\src\BluetoothSerial\BluetoothSerial.cpp:996:30: error: ‘ESP_BT_CONNECTABLE’ was not declared in this scope
C:\Users\LENOVO\Documents\Arduino\Projects\RTK_Surveyor\src\BluetoothSerial\BluetoothSerial.cpp:996:50: error: ‘ESP_BT_GENERAL_DISCOVERABLE’ was not declared in this scope
exit status 1
Error compiling for board ESP32 Dev Module.
Thanks in advance for your help.
