I am having an issue connecting to my RTK-Surveyor.
When I power on the device I am able to get the PPS light blinking but I am not able to connect via Bluetooth or WIFI. I have followed previous posts and haven’t gotten very far.
when I plug USB in the ESP32 slot i get gibberish
when I plug USB into the ZED slot I get a successful connection to u-center
The only indicators that I see is one dimly lit led on the 10cm indicator.
as far as switches and other things inside are concerned, I have had the device open but not recently and i haven’t ever modified the DIP switches.
the outside switches are both down (until i turn on the device to test) at which point i turn on the device but leave it in rover mode
Thanks for any assistance you might provide.
This is the serial output of the ESP:
rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
invalid header: 0xffffffff
ets Jul 29 2019 12:21:46
