RTK Torch for professional use and setup
Hello, my team is interested in getting an RTK Torch for it’s base station capability for our racecar testing. A few questions we have:
-Is this product designed for professional use or is it more of a hobby grade unit?
-What is the setup procedure and does it need a set amount of time to calibrate its position?
1 - it’s in-between…it has professional accuracy and build, but is a new product that is still undergoing active development/improvements and fixes on the software side
2 - it depends on how recently you were using it (if you have a hot fix or not), but generally from a cold unboxing in the field https://www.youtube.com/watch?v=HCg9rD4FEdA you’d be going at full accuracy in 30 sec to maybe 5 minutes (and maybe 15 minutes the first time setup/learn to navigate the software/etc https://docs.sparkfun.com/SparkFun_RTK_ … art-torch/)
