Samd21 Pro RF cannot get the example code to compile in Arduino
Hi there~
I am following the example and have setup TTN and have all the developer credentials generated, but when I copy my DEVADDR into the example I get an error.
The line in the example code:
// LoRaWAN end-device address (DevAddr)
static const u4_t DEVADDR = { 0x26, 0x02, 0x1B, 0xE0 };
I get an error:
“scalar object ‘DEVADDR’ requires one element in initializer”
Any ideas?
Try
static const u4_t DEVADDR = 0x26021BE0;
/mike
Ok that worked. Probably want to update the instructions to note this subtle nuance. Thanks for the quick reply!
@partsoven were you able to get the thing to work with TTN? If yes which example code did you use? Thanks
