SEN-11050 Flame testing of components
We are looking to incorporate the SEN-11050 temperature sensor assembly into a small run of products we are developing.
For this product s we need to comply with IEC 62368-1 and the flame requirements for internal components, in the case for the sensor assembly it would need to meet or exceed compliance with UL94 V-1 performance class.
Has there been any flame testing on the temperature sensor assembly, or do you have datasheets for the subcomponents (wire, heat shrink thermowell) showing any flame testing completed on them?
Ideally the datasheets would have testing showing UL testing results (and hopefully compliance to our spec), allowing the whole temp assembly to be considered compliant by default.
No :-/ Just the stuff provided by the datasheet https://cdn.sparkfun.com/assets/7/5/9/5 … 18B20_.pdf
