SIK master code download error
I have tried downloading the SIKcode v4.0a and 4.1 but the files are not transferring correctly, when I try to open them with WINZIP the message is that the files are incomplete or corrupt. Trying to set up the ArduinoIDE to run a RedBoard from the SparkFun Inventors Kit and also to run a new Artemis with Qwiic connector. Any ideas on what the problem might be?
Hey there - I am not really familiar with the SIK but I am quite familiar with Artemis boards. Maybe I can help.
  1. I tried to find the SIK files that you mentioned without much luck. Can you post the originals on a message (or a link of where to find them would help too)
  2. As for the Artemis are you able to run any examples? Did you have trouble installing the board support?
Here is the guide to using Artemis boards with the Arduino IDE
https://learn.sparkfun.com/tutorials/ar … stallation
Good luck and don’t hesitate with any questions!
Maybe you can download the examples from the github repository
https://github.com/sparkfun/SIK-Guide-Code/tree/v41
Clone the repository using Git or download the repository as a zip file and unzip.
Why don’t you download the sample zipped files from the GitHub repository?
Then use them in your program. You can even use the GitHub files.
