Hi. What would happen if the green pad in JP2 is damaged. Can I still use external antenna?
Yes…you wouldn’t be able to use the on-board antenna
Sever the connection there @ JP2 (desolder, cut) and puta solder blob on connecting the pads to its immediate left
so that it looks like this
And you can use the rest of the guide ![]()
https://learn.sparkfun.com/tutorials/simultaneous-rfid-tag-reader-hookup-guide/using-an-external-antenna
Good day. Thank you for anwering my question, but just for clarification: Is the L1(Inductor) not in use when using the external antenna?
Thank you again
