I am using a Simultaneous RFID Tag Reader (SEN-14066 M6E Nano) with the SparkX UHF RFID Ring Antenna (SPX-15113).
The SRTR is being used as a shield for the Arduino Uno.
To make it easier to switch between external and onboard antenna, I soldered switches to both pads. Testing out the connectivity, it seems that a pair of each pads on SJ1 and SJ2 are connected (please see video https://www.youtube.com/watch?v=7cjAmhFOgMI) so it’s impossible to just connect the pad for external or onboard antenna - connecting one connects both. I am also using a 5V power supply and have a USB hooked up from my Arduino Uno to my computer.
The code for Example1_ConstantRead compiles and uploads, but consistently says scanning, even when there is an RFID tag directly next to both the onboard and external antenna. Could this be due to the voltage being split by the two antennas? I am using these Murata ultra small UHF RFID tags (KIT-16464). https://www.sparkfun.com/products/16464
How do I fix this soldering issue?
Video: https://www.youtube.com/watch?v=7cjAmhFOgMI
Thanks! ![]()
