On the SparkFun Buck-Boost Converter board, the enable input is labeled EN with a line over it.
A line over a logic identifier mean NOT, or active low. So a line over EN means EN (enable) is active low, in other words it is enabled when pulled low. This is incorrect. When EN is pulled HIGH (default), the chip is enabled.
