I thought that if it had a Qwiic connector, it would work. Feeling kinda stupid at the moment.
I need to measure voltage and current. Any ideas? Will the Tech team write drivers for these in the future? Are the sensors confirmed NOT working with the Datalogger?
You can use most any 3.3v-IO MCU that has i2c and wire both sensors to the bus (Raspberry Pi, etc)…if you don’t have one already, I’d get one that has an SD card (or add a logger to one)
It also might be a good idea to disable one sensor board’s set of i2c pull-up resistors (sever the 2 small traces between the “i2c” jumper pads); I made a quick illustration of where you’d need to cut the traces (highlighted in green) on the INA228 (leaving the ADS1219 unmodified)
No, but most any basic sketch should be compatible…I usually make a test sketch that just sends a bit of serial text output. Are you following this? ThingSpeak | DataLoggerIoT Documentation (it covers basically everything we know about it)
