Sparkfun facet firmware change request
Hi Sparky.
I have been using a Sparkfun facet as a base for ntrip corrections, sharing wifi from an lte cell phone, in conjunction with a professional team from another brand. First I locate it with survey in and then I write down the coordinates obtained and to continue working the next day I place it at the base as a fixed base at the same point, where I left a wooden stake and entered the coordinates obtained the day before.
I have been very satisfied.
Because of that I wanted to request a couple of things:
  1. if the Wi-Fi signal of the Sparkfun facet is cut, the reconnection time is very short, it is 30 seconds and after that it cannot be activated anymore, to continue using the same base coordinates quickly.
You must then start another survey with survey in and that delays everything.
I would like the Wi-Fi reconnection time to be extended after a disconnection, at least 10 minutes, to be able to fix the Wi-Fi and continue working.
  1. I would like that after a mobile base location with survey in, the coordinates obtained automatically pass to the coordinates to be used in a fixed base, so I don’t have to enter them manually.
That would be fantastic.
That’s it for now, as long as I continue to use Sparkfun facet in daily topography tasks, I will communicate to collaborate within my possibilities.
Greetings and have a great day.
PD: sorry for the Google translation
These are great requests. Please post them on the repo so that other developers can see your suggestions: https://github.com/sparkfun/SparkFun_RT … are/issues
I follow your advice. I’ve already uploaded it to Github.
Keep in touch.
Awesome! Thank you, that helps us.
