In ntrip base mode connected to wifi, if you disconnect and connect within 30 seconds, everything is still working fine.
If it exceeds 30 seconds, ntrip stops sending data and does not try to connect to wifi again, as I was informed in other messages on Sparkfun’s Github.
Does anyone know about this? My intention is that after the Wi-Fi problem is solved and the new connection is achieved, ntrip corrections continue to be transmitted using the same base data obtained with survey in and not having to start the procedure again.
I already mentioned it in the repository days ago.
Actually it is not a technical problem of the Facet, but of my lte phone.
When using it in the field, it sometimes cuts the Wi-Fi connection and what I mentioned before happens. And if you are far from the base it can be frustrating to go back and fix the new start of ntrip corrections and additionally change the base coordinates.
If you can tell me something else I would be very grateful.
