Hello
I just wanted to install firmware 3.8 on my RTK Facet - over-the-air.
Unfortunately I can’t confirm that it worked:
When I clicked “Update Firmware”, after a short while the message appeared that the device was resetting. Then nothing happened anymore.
I turned the device off and on again, it started the old FW v3.7. Then activated the config mode again and clicked “Update Firmware” again, then nothing happened at all.
I thought to myself, then I would upload the FW file via “Upload Firmware” and clicked on it. Then nothing happened, not asking to select a file to upload.
So I connected the device serially like before: There was no new FW file to be found on the SD card.
So I updated everything via serial connection, like I always do…
Greetings
Roman
