Hello
I’n new with the Sparkfun RTK Facet (Firmware v2.4). It works very well.
But I don’t understand quite a lot about how to update the firmware (according to https://docs.sparkfun.com/SparkFun_RTK_ … re_update/)
In the mentioned serial connection, the is NO menu item for a Firmware update.
I see exactly this base menu:
SparkFun RTK Facet v2.4-Aug 27 2022
** Bluetooth broadcasting as: Facet Rover-83BA **
Menu: Main Menu
1) Configure GNSS Receiver
2) Configure GNSS Messages
3) Configure Base
4) Configure Ports
5) Configure Logging
p) Configure Profiles
r) Configure Radios
s) System Status
x) Exit
Could the reason that I don’t see a “Firmware Update” menu item with a serial connection be that an SD card with firmware has to be inserted first?
Last but not least, I cannot find any firmware for the “Sparkfun RTK Facet - GPS 19984”. I found the github repository, but there is mentioned a firmware “Sparkfun RTK Surveyor”.
Could somebody help me how to find the firmware for the Sparkfun RTK Facet?
As I saw, other installed the Surveyor firmware on the Facet by mistake… ![]()
I’ve done so many firmware updates on so many different devices, but I’ve never lost myself so much. I’m really embarrassed. Maybe someone can clearify the one or other issue with me? :oops:
Kind regards
Roman
Switzerland
