I used to use my setup—SparkFun RTK Facet, iPhone, SW Maps, and an NTRIP connection—without any issues.
Recently, however, my SparkFun RTK Facet has started repeatedly disconnecting from my iPhone. When this happens, I have to reconnect the RTK Facet to the iPhone, reconnect the NTRIP client in SW Maps, and then continue working. Unfortunately, after another 10–20 seconds, it disconnects again and I have to repeat the whole process.
So far, I have tried:
- Restarting/resetting my iPhone
- Restarting/resetting the RTK Facet
- Deleting and reinstalling SW Maps
None of these steps have solved the problem.
Has anyone experienced a similar issue with the RTK Facet, iPhone, and SW Maps setup? If so, were you able to identify the cause or find a solution?
Any suggestions would be greatly appreciated. The frequent disconnections have made the setup almost unusable in the field.
Thank you.
