Hello everyone, let’s see if someone can give me a hand, because I’m about to go crazy
. My intention is to read several RFID tags simultaneously within a range of less than 1m. To do this I have purchased the following products (in principle all compatible with each other):
SparkFun Simultaneous RFID Reader - M6E Nano: https://www.sparkfun.com/products/14066
UHF RFID Antenna (RP-TNC): https://www.sparkfun.com/products/14131
Interface Cable RP-SMA to U.FL: https://www.sparkfun.com/products/662
Interface Cable for RP-TNC to RP-SMA - 1m: https://www.sparkfun.com/products/14132
Ultra-Small UHF RFID Tag Rain - 10 Pack: https://www.sparkfun.com/products/16464
SparkFun Serial Basic Breakout - CH340C and USB-C: https://www.sparkfun.com/products/15096
I have the reader connected to a lab power supply that provides 5v continuous and a limit of 1.5A. This power is provided by the 2mm JST connector, and I have the JP1 junction cut so that the FTDI only provides communication with the module and not power.
For testing I have used the Jadak Universal Reader Assistant (URA) software. If I read the tags with the integrated antenna they work at a very small distance, but they work.
After buying the external antenna I mentioned before and desoldering the solder that gives the antenna from the PCB and soldering the one that gives the u.FL connector the board in principle is ready to work. I have configured URA with several regions, OPEN, EU3, EU4, NA, among others, selected antenna 01, varied the read/write power with several values (even reaching the maximum 27 db). With no configuration I manage to read a tag that is above the antenna (not to say far away a finger, or a few centimeters). I have checked the soldering and desoldering to the external antenna and the connector, everything is correct checked with a multimeter. I have checked that the antenna ground leads to the rear metal part of the antenna. I have checked the wires and everything is ok.l However, I am not able to read any label when before with the PCB antenna at least I could read some even if it was very close.
Can anyone think of what I might be missing? I honestly don’t know what is going on, because it is not normal that the label placed on top of the external antenna, touching the white plastic, I am not able to read any label.
Thanks in advance.
