Sparkfun Single Channel Gateway EV_JOIN_TXCOMPLETE: no JoinAccept Helium Network
Hi SparkFun Team!
Not sure if this was possible, but I modified your code for the Single Channel Gateway and I’m trying to connect to the Helium Network (there are several hotspots around me). Currently, I get EV_JOIN_TXCOMPLETE: no JoinAccept.
Here is my antennahttps://www.dropbox.com/s/k92azmtj8fr9t … 2.jpg?dl=0 it’s a 915 spring antenna from Adafruit.
The code is from here: ```
https://learn.sparkfun.com/tutorials/1w-lora-micromod-function-board-hookup-guide/lorawan-examples
Is there any reason why this would not work?
Best Regards,
Mike
Hi, does the product work if you just copy-paste and upload the code given in the sparkfun’s hook-up guide?
