hi I’m new to SparkFun and programming, and recently I bought SparkFun Transparent Graphical OLED Breakout for interest to tryout. Can i ask where to buy the cable for this and which SparkFun Board do you recommend to use with this? Thank you. hope to hear from you soon.
Hello zversion100 and thanks for your post!
Any of our Qwiic cables will work with that display. I’d recommend the [100mm cable to experiment with but we have other sizes as well. We also have an [assortment cable pack that includes 10 different cables and is a better buy than just getting them individually. (Plus you will probably want more cables later to connect multiple Qwiic boards.)
For an Arduino to connect to the display, our [RedBoard Qwiic would be ideal since it has a Qwiic connector built in. No shields or soldering are needed to get started, just plug the display into the RBQ and you’re ready to go.](SparkFun RedBoard Qwiic - DEV-15123 - SparkFun Electronics)](SparkFun Qwiic Cable Kit - KIT-15081 - SparkFun Electronics)](Qwiic Cable - 100mm - PRT-14427 - SparkFun Electronics)
