hello
producst in my sitem
celullar shiedl by sparkfun
https://www.sparkfun.com/products/13120
weather shield by sparkfun
https://www.sparkfun.com/products/12081
sunny buddy by sparkfun
https://www.sparkfun.com/products/12885
Hello
THESE son Items I’m using for my meteorological station.
The real problems arise when food itself The Celullar shield From sunny companion (I mention the food support part Celullar shield).
WHEN connect a sun Falla travez friend, is not stable Never connect the GPRS, but if you connect La Pila Directly jala fine, clear This not work because I would never be charging the battery.
I want to know why this happens, that many had problems with sunny colleague because not I charge the battery efficiently.
The stack is a (lipo 3.7v 6000mAh)
I have my working system.
I tired Correct Things miles Sparkfun gives overlooked.
I had to correct Bookstore cullular with shield to work (Arduino Mega), I had to modify the hardwarepara which will pull Similarly with (Arduino Mega), I had to correct Bookstore (phant) to Postera on the server (data .sparkfun.com)
And the truth is that more will correct, but I want to continue no longer correcting things, no please help me saber because first uncharged look Stack sunny partner in Second it does not work well the Celullar protection when connected with the sun companion.
URGE please.
