Express base does not appear to connect via bluetooth the rtk express with the cell phone. I followed the steps and nothing.
I can not connect the redmi note 10 pro with the sw maps, the application launches.
What other application can be used.
Can you share a screen shot of the error “does not connect”?
I don’t think you will see positional data over Bluetooth in the mode shown in your picture.
There is no reason to connect to a device while it is in base mode.
Your image shows a unit in base mode while the unit’s HPA (horizontal positional accuracy) is greater than 1m. This is settle mode. The device doesn’t transmit anything over Bluetooth during this time.
Put the device into Rover mode and you’ll see your position in sw maps.
Translation to English:
"SW Maps continues to fail
Send bug report to Mi for analysis ? This report may contain personally identifiable information. Your report will be used to help fix this error and will not be shared in any commercial context. View Summary Cancel"
That is a application error related to SW Maps, not the RTK product. I do not know why SW Maps is failing but I will ask the developer to have a look.
You may want to try Field Genus: https://sparkfun.github.io/SparkFun_RTK … eld-genius You can try it out to see if your phone will work or not.
It looks like SW Maps does not have Bluetooth permission. You may have denied the permission when running the app for the first time, or the system revoked the permission somehow. We are working on a fix to resolve this.
For now, you should be able to long press the SW Maps icon and open “App Info”, and then allow the Bluetooth permission manually.
