Hello Sparky,
I have been trying to update the firmware on my Sparkfun RTK Express unit.
I have successfully downloaded the latest firmware file I could find “RTK_Surveyor_Firmware_v2_3.bin” onto the SD card and put the SD card into the SRE unit.
The SRU unit was connected from its “Config ESP32” USB C port to my PC’s USB port.
I was able to create a 115200 baud Com port connection between the PC and SRE, using Tera Term.
The text between the lines of dots below is a copy of the terminal window’s display.
UBX file size: 201486 - Generation rate: 0.0kB/s - Write speed: 0.0kB/s
Batt (100%): Voltage: 4.19V Discharging: 0.00%/hr Green
w
SparkFun RTK Express v1.9-Dec 8 2021
** Bluetooth broadcasting as: Express Rover-9D2E **
Menu: Main Menu
Configure GNSS Receiver
Configure GNSS Messages
Configure Base
Configure Ports
Configure Logging
Display microSD contents
d) Configure Debug
r) Reset all settings to default
f) Firmware upgrade
x) Exit
r
Resetting to factory defaults. Press ‘y’ to confirm:
ySettings erased successfully. Rebooting. Good bye!
ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1240
load:0x40078000,len:13012
load:0x40080400,len:3648
entry 0x400805f8
ZED-F9P firmware: HPG 1.13
Reset reason: ESP_RST_SW
microSD online
EEPROM is blank. Default settings applied
MAX17048 configuration complete
Updating UART1 rate
Updating UART2 rate
GNSS configuration complete
Accelerometer configuration complete
WiFi Stopped
State: Rover - No Fix
Appending last available log
Log file created: SFE_Express_220804_214702.ubx
UBX file size: 201517 - Generation rate: 40.3kB/s - Write speed: 56226.8kB/s
UBX file size: 208197 - Generation rate: 1.3kB/s - Write speed: 1214.3kB/s
w
Menu: Main Menu
Configure Base
Configure Ports
Configure Logging
d) Configure Debug
f) Firmware upgrade
x) Exit
f
Menu: Update Firmware Menu
- Load RTK_Surveyor_Firmware_v2_3.bin
x) Exit
11
WiFi Stopped
Bluetooth turned off
Loading RTK_Surveyor_Firmware_v2_3.bin
Update begin failed. Not enough partition space available.
x) Exit
No user input received.
Essentially, after not being able to update the firmware, I disconnected all, and re-started.
I reset settings to default: this appears to have been successful.
But when I try to load the firmware update, I get the error message “Update begin failed. Not enough partition space available.”
The text below between the lines of dots is the directory listing of the SD card.
Volume in drive H has no label.
Volume Serial Number is 6339-3361
Directory of H:\
01/01/2021 12:00 am 3,466 SFE_Express_Settings.txt
04/08/2022 09:34 pm 2,049,049 SFE_Express_220804_205441.ubx
04/08/2022 05:57 pm 1,997,360 RTK_Surveyor_Firmware_v2_3.bin
04/08/2022 09:44 pm 609,960 SFE_Express_220804_213511.ubx
04/08/2022 09:45 pm 32,323 SFE_Express_220804_214511.ubx
04/08/2022 10:12 pm 225,565 SFE_Express_220804_214702.ubx
8 File(s) 4,917,757 bytes
0 Dir(s) 31,897,255,936 bytes free
The card seems to have the correct .bin files
Could you please advise how to get past this, please?
ADLY
