Tracking with Ultra-Small UHF RFID Tag
Hey,
I want to make a project where I would track one insect with this Ultra-Small UHF RFID Tag (https://www.sparkfun.com/products/16464) in the box.
Is it even possible to track the insect in a box 40x30x30 cm with this RFID tag glued on them?
I want to get the exact coordinate (x,y,z) of the tag in the box.
How many antennas and readers should I have? I have lots of space for antennas.
Do I need the any signal amplifier?
Can you please advise me which (and how many) antenna and reader should I get.
My goal is to quickly find a specific insect among other insects.
Can RFID tag make sounds when I press the button on reader?
Thank you for your help
Domen
Your best bet would be
Antenna https://www.sparkfun.com/products/14131
1st adapter https://www.sparkfun.com/products/14132
2nd adapter https://www.sparkfun.com/products/662
Reader https://www.sparkfun.com/products/14066
Then go through the hookup guide https://learn.sparkfun.com/tutorials/si … okup-guide that will walk you through how to use the reader
To get exact x/y/z you’d probably want to get 2-3 setups and program then separately, then integrate the data from the signal strength of each tag into a main program that is tracking them
